Trailer Guides
rsscoggins
Re: Trailer Guides
#16 Post by rsscoggins » Fri Jun 03, 2016 8:53 am
Bamaman wrote: The above posts guides are what you don't want to use on a pontoon boat. They'll dent your toons in some situations, especially on windy days.
My trailer has 10' long horizontal carpeted bunks running inside the outside toons--starting about 4' from the rear of my trailer.
Why do you say that the post guides will dent the toons - I definitely don't want to do that. I did pick up my boat yesterday and it does have a set of the non-floating guides on the back.
You state that yours has a carpeted bunk - do you have a pontoon or a tritoon. I see how the carpeted bunk could work on a pontoon but on a tritoon unless there are bunks on both sides of the support, I can see the center toon contacting the metal frame of the bunk support if you come in at an angle.
rsscoggins
Re: Trailer Guides
#17 Post by rsscoggins » Fri Jun 03, 2016 8:56 am
Gonefishing wrote:Check out 4c innovention I have their loading guide system on mine and love it. Windy days not a problem at all and I am mostly by my self when out. That was the main reason I purchased it. Very easy to install and works great.
4c doesn't make anything for a tritoon do they - only pontoons.
Gonefishing
Re: Trailer Guides
#18 Post by Gonefishing » Fri Jun 03, 2016 4:50 pm
Yes 4c does make a set for a tritoon.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
rsscoggins
Re: Trailer Guides
#19 Post by rsscoggins » Fri Jun 03, 2016 7:57 pm
Gonefishing wrote:Yes 4c does make a set for a tritoon.
I emailed 4c with some questions - specifically how do they brace the two sides with a tritoon as they show a cross brace on the pontoons
Also how do they ensure that the center toon doesn't contact the metal on the inside.
