Steering question
Steering question
#1 Post by bansil » Tue May 01, 2018 5:52 am
So it literally is like steering a duece with no power steering while sitting in a paved parking lot :punchballs
So how hard is your boat to steer? 2 hands on small wheel sucks
I got to looking last night and I think I found some parts of the problem, the PO made too sharp of a turn behind gas tank, and then under the boat it goes side to side 4 times and the cable is tightly zip tide to cross members and final thing? going up through the floor it is under way to much stress
Looks like I need to move helm a few inches towards the middle and reroute the cable, all grease fittings have been hit that I could find
I kind of want a big spoked wheel also :thumbsup
Re: Steering question
#2 Post by curtiscapk » Tue May 01, 2018 6:18 am
If I were you I'd get a correct size cable instead sounds like that one is too long. Mine has a foot of slack and that's it. "and then under the boat it goes side to side 4 times" crazy!
When replacing the steering system on your pontoon boat you will need the following measurements to determine the cable length.
A. Measure from the center of your pontoon's console to the edge of the starboard side of your deck.
B. Measure your pontoon boat's deck length from the center of your console to the point where your engine is attached to the transom.
C. Measure from the starboard edge of your deck to the center of your transom.
Add A,B, C + 12", round up to the closest foot and that's the length you need.
https://www.pontoonstuff.com/collection ... ing-system
https://www.pontoonstuff.com/collection ... ring-wheel
#3 Post by bansil » Tue May 01, 2018 8:27 am
Great info! Thanks!
#4 Post by bansil » Tue May 01, 2018 5:56 pm
Ohhhh :donno i swear..... $!#×:=€€^_^*....
I will post pictures in the am.....there really...honestly...are...reasons that folks that dont know f--- about mechanics and shit....really shouldn't work on more than a tan....
The shifter and steering cables are....at the moment. ...not worth.....errr...crap.
Instead of cruising.....i will be....re-doing...
And in all honesty. ...i am ghetto as....this is bad
Ugh...time to flush...and refill my wine glass :thumbsup :mrgreen:
Retired OG
#5 Post by Retired OG » Wed May 02, 2018 6:18 am
I feel your pain.... :biggrin2 ...the motor that came with my old pontoon, looked like 50 different Okies had tinkered with it in a vain attempt at getting it to run properly, instead of getting a service manual and doing things right....kind of like "Hold My Beer While I Try This".....
Soonertoon
#6 Post by Soonertoon » Wed May 02, 2018 6:42 am
Easy on the Okies comments !!! Im Sooner born and Sooner Bred ...and when I die Ill be Sooner dead ...but I'd rather be dead than in Stillwater...BOOMER SOONER!!!!!
Broken Arrow Ok
2014 G3 Suncatcher
115 Yamaha 4 stroke
#7 Post by bansil » Wed May 02, 2018 10:18 am
Found some issues with cable,it is basically pinch in 6 place where it was "bent" to go through holes and crap.
It will be a pain to deal with on Friday
#8 Post by curtiscapk » Wed May 02, 2018 11:21 am
does it really go back and forth?
#9 Post by bansil » Wed May 02, 2018 3:14 pm
I undid 1 loop last week to try and help it and it work some still horrific ,this was taken last night
2018-05-01 19.03.34.jpg (140.99 KiB) Viewed 4385 times
2018-05-01 19.31.15.jpg (97.59 KiB) Viewed 4385 times
2018-05-01 19.02.39.jpg (132.76 KiB) Viewed 4385 times
2018-05-01 19.02.15.jpg (48.59 KiB) Viewed 4385 times
2018-05-01 19.01.48.jpg (131.28 KiB) Viewed 4385 times
You count every place in contact and they are stressed, all holes wrong places and it will be fun, i have a pretty good plan laid out to try and salvage thos...
jrolin1
#10 Post by jrolin1 » Thu May 03, 2018 4:42 am
I would get a correctly sized cable at this point. That one likely has wear points that increase the resistance.
#11 Post by curtiscapk » Thu May 03, 2018 6:44 am
yikes I think you'd see dramatic difference with something like this....
steering cable.JPG (44.81 KiB) Viewed 4361 times
