hyper
#16
Post
by hyper » Thu Aug 25, 2011 10:24 am
curtiscapk wrote:dash
You need some gas in that there boat son!!!
2003 50HP Elpto 2 stroke
Ron Burgundy
#17
Post
by Ron Burgundy » Thu Aug 25, 2011 10:29 am
Curtis, did you know your fuel gauge is broken?
#18
Post
by curtiscapk » Thu Aug 25, 2011 10:55 am
Smart ass fuckers and I quote!
hard to see but right gauge...yes I know my fuel gage is broken.
Ron Burgundy
#19
Post
by Ron Burgundy » Thu Aug 25, 2011 12:06 pm
fastbackford
#20
Post
by fastbackford » Thu Aug 25, 2011 2:14 pm
For the life of me, I can't find a place to hook a water pressure gauge up. The main most pee hole pees from the front of the motor right above the foot and there are two lesser pee holes down below the engine itself. Neither place looks like I can get to it without tearing the motor all apart. fwiw, it's an 88 or so Evinrude 70hp.
Government Warning:
Governments are extremely dangerous.
Death, imprisonment, theft of property
and loss of freedom will result from
giving them too much power.
GregF
#21
Post
by GregF » Thu Aug 25, 2011 6:54 pm
Look below the thermostat in the water manifold for a plug maybe all the way toward the bottom.
1974 Harris
70 HP 4 stroke EFI Yamaha
killerkernrich
#22
Post
by killerkernrich » Thu Aug 25, 2011 7:02 pm
GregF wrote:Look below the thermostat in the water manifold for a plug maybe all the way toward the bottom.
THEN what you have to run a return line to the gauge & mount it into the dash....might be a job for a pro??
PLP Member
NRA member
UFC fan
fastbackford
#23
Post
by fastbackford » Fri Aug 26, 2011 3:19 am
I am more than mechanically capable of running whatever kind of line needs to be run but I see no t-stat connection on the manifold or a plug to tap in to. But it is looking like I'm going to need a professional, or at least a more experienced set of eyes on the project to point out what I am obviously missing. I'll take some pictures and post up what the dealio is.
Government Warning:
hyper
#24
Post
by hyper » Fri Aug 26, 2011 5:04 am
Can you take a picture of the motor so we can see it, we may be able to point you to the correct spot if we had pictures.
hyper
#25
Post
by hyper » Fri Aug 26, 2011 5:05 am
GregF
#26
Post
by GregF » Fri Aug 26, 2011 8:16 am
I really do not know much about old OMCs I am a Mercury guy but I bet you can find a dealer mechanic who can get you going. Take a box of dougnuts
1974 Harris
