Poor Neighbor
Poor Neighbor
Bad start to the season.
- Copy of sinking2.JPG (96.17 KiB) Viewed 4298 times
- Copy of sinking1.JPG (99.83 KiB) Viewed 4297 times
2004 Hurricane GS211
Yamaha 150 OX66
Yamaha 150 OX66
Re: Poor Neighbor
Wow-any idea how that happened?
Re: Poor Neighbor
It was REALLY windy in Ocean City, MD last Friday night. The tie down hook that is welded to the pontoon got yanked off and left a big hole in the tube.steveiam wrote:Wow-any idea how that happened?
Yamaha 150 OX66
Yamaha 150 OX66
Re: Poor Neighbor
That's why you use that hook for lifting only, it doesn't like side forcesomar174 wrote:It was REALLY windy in Ocean City, MD last Friday night. The tie down hook that is welded to the pontoon got yanked off and left a big hole in the tube.steveiam wrote:Wow-any idea how that happened?
Re: Poor Neighbor
Yep...weather around here in spring has gotten progressively worse every year. See what happened to my boat despite 5 cleats with 1/2 inch lines
I won't miss slipping here at all.
Check out Tow Boat US's Facebook page for the upper Chesapeake.
Guy made a ton of $$$ for multiple ungroundings, boats broke loose from slips, and 2 boat fires. One guy in a cruiser ran over a jetty and sunk his vessel.
- evinrude2stroke
Re: Poor Neighbor
Interesting, I wonder if his insurance will cover it based since it wasn't tied to cleats
Dave
Re: Poor Neighbor
how about pulling tubes and skiers? I've read many opinions about that, my dealer said it was ok to use the eyes for pulling tubes, i use a bridle hooked on both.HandymanHerb wrote:That's why you use that hook for lifting only, it doesn't like side forcesomar174 wrote:It was REALLY windy in Ocean City, MD last Friday night. The tie down hook that is welded to the pontoon got yanked off and left a big hole in the tube.steveiam wrote:Wow-any idea how that happened?
How about towing another boat, will they hold up to that stress?
shiat, i'm getting all mixed up.
here, pull my finger
2011 Godfrey Sweetwater
Yamaha F70
Yamaha F70
Re: Poor Neighbor
Not sure about that particular Starcraft, but my 2006 didn't have cleats. Just the eyelets welded to the tube. No other place to tie off.
Yamaha 150 OX66
Yamaha 150 OX66
Re: Poor Neighbor
They are made to pull straight up, people have got away with using them for tow rope use, some have had cracks form, no way would I pull and boat with them, if you don't have cleats in the back, put them on, or at least some good strong eyelets.
Might not cause a problem, but why take a chance
Re: Poor Neighbor
Yep. I was specifically told by Tracker ( I e-mailed the factory reps) NOT to use the log eyelets for tying to a slip. The port and stern cleat welded onto the log has a HUGE backer inside the log, that's fine...eyelets have no side to side strength. A lot of 'toons on the bay have the log eyelets bent or broken off due to our nasty weather.
Re: Poor Neighbor
+1 on the don't use the eyelets concept.
I always use dock rings with four bolts each thru the rub rail and through the deck wood, with extra large fender washers and nylock nuts underneath. Never a problem.
- evinrude2stroke
Re: Poor Neighbor
Mine didn't come with cleats either. I used the eyelets for a long time but after reading about them cracking I installed cleats just to be on the safe side.omar174 wrote:Not sure about that particular Starcraft, but my 2006 didn't have cleats. Just the eyelets welded to the tube. No other place to tie off.
Dave
Re: Poor Neighbor
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
Re: Poor Neighbor
That's what they say.
Re: Poor Neighbor
I had an eyelet right behind my nav light or a cleat a little further back on the side, I tied mine too. What is that behind your bumber looks like a cleat to me?
- SAM_0441.JPG (286.79 KiB) Viewed 3161 times
