Best location to mount transducer
bradcox100
#1 Post by bradcox100 » Tue Jun 04, 2013 1:29 pm
I have searched this forum, but I don't see a best location to mount a transducer for my new Lowrance Elite 4 DSI fishfinder.
I see that most people say to mount the transducer on the bracket that goes around the aerator pump on the left toon at the rear. But I saw where one person has mounted the transducer on the transom.
I haven't drilled any holes yet for the transducer. So what does everybody suggest?
Brad
Brad & Ali
2013 20' Sun Tracker Fishin' Barge
Mercury 60hp 4-Stroke
2007 Ford F150 Lariat SuperCrew 4X4
BobG
Re: Best location to mount transducer
#2 Post by BobG » Tue Jun 04, 2013 1:38 pm
Right bracket. There's no pump there.
redbeard
#3 Post by redbeard » Tue Jun 04, 2013 1:47 pm
BobG wrote:Right bracket. There's no pump there.
1+
#4 Post by curtiscapk » Tue Jun 04, 2013 2:31 pm
Since it is a Tracker it probably has a ladder....and no bracket at all.
#5 Post by lakerunner » Tue Jun 04, 2013 4:15 pm
Be sure and mount the bracket as close to bottom as possible. Toons make lots of bubbles and disturbed water and transducer needs clean water to work right. Don't tighten so much it won't kick up when it hits something.
evinrude2stroke
#6 Post by evinrude2stroke » Tue Jun 04, 2013 6:20 pm
On the bracket. It also has to be level. Your kit should have shims in case you need them. Be sure to use stainless steel hardware.
Dave
#7 Post by lakerunner » Tue Jun 04, 2013 8:46 pm
evinrude2stroke wrote:On the bracket. It also has to be level. Your kit should have shims in case you need them. Be sure to use stainless steel hardware.
Level on a side to side you mean? It doesn't on vertical because transducer is adjustable
bradcox100
#8 Post by bradcox100 » Wed Jun 05, 2013 2:43 am
I think curtiscapk is correct, I can't find a bracket on the right side of my Tracker. So I will mount it on the aerator bracket on the left side. I just wanted to be sure before I start drilling into our new boat, ha.
Back of Boat.jpg (152.68 KiB) Viewed 8592 times
Brad & Ali
BobG
#9 Post by BobG » Wed Jun 05, 2013 7:25 am
bradcox100 wrote:I just wanted to be sure before I start drilling into our new boat, ha.
The first hole is the hardest. After that, it gets easier.
That's like the first time I took a sawzall to the fender openings on my 1995 Suzuki Sidekick (with 33" tires).
steveiam
#10 Post by steveiam » Wed Jun 05, 2013 8:51 am
I have a tracker also-and it has brackets on both toons.
I have a transducer on both.
#11 Post by curtiscapk » Wed Jun 05, 2013 8:52 am
steveiam wrote:I have a tracker also-and it has brackets on both toons.
with a rear ladder?
oldcoot
#12 Post by oldcoot » Wed Jun 05, 2013 9:17 am
My '03 Suntracker doesn't have a ladder in the rear...so mine is mounted to the right bracket....
Jim & Jill
East Peoria, Il.
Illinois River Tooners
90hp Tracker Mercury
"the Jillie Marie"
steveiam
#13 Post by steveiam » Wed Jun 05, 2013 9:41 am
with a rear ladder?
Yes Sir--
steveiam
#14 Post by steveiam » Wed Jun 05, 2013 9:43 am
It is a transducer for down/side imaging and when we are using the ladder we just flip it up.
steveiam
#15 Post by steveiam » Wed Jun 05, 2013 9:52 am
Here is a closer shot-
